Date/Time: Fri, 17 Jan 2025 06:08:58 +0000
Transparency Level settings
View Count: 1107
[2017-12-08 10:46:45] |
ticinotrader - Posts: 397 |
Dear Support, Can you please let me know where can I find the Transparency Level settings what affect the transparency of Large Volume Trade indicator's drawings? I tried to locate it at Graphics Settings - Global/Other based on the documentation but there is no option there to change on this tab. I use SC v1656. Thank you! |
[2017-12-08 12:15:24] |
This is on the Subgraphs tab of the Study Settings window for the study: Transparency Level for Fill Styles. We will make sure the documentation is up-to-date. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
