Date/Time: Fri, 17 Jan 2025 06:09:47 +0000
Bitmex Trading Allowed ?
View Count: 1042
[2017-12-08 06:58:03] |
vg - Posts: 1 |
Hi I want to trade bitcoin using sierra chart on Bitmex. Is it possible ? I did try this using the DOM Window for XBTUSD symbol on bitmex, although all of my trades were visible in sierra chart, my balance did not update on BITMEX accordingly. I made sure i was connected to the bitmex mainnet for live trading. Please advise if live real time trading on bitmex is allowed or if I am doing something wrong. Thanks Vishal |
[2017-12-08 07:37:16] |
BitMEX trading is fully supported. You need to follow through the instructions here: http://www.sierrachart.com/index.php?page=doc/BitMEX_Trading.php#SetupInstructions Also make sure that Trade >> Trade Simulation Mode On is disabled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 07:37:33
