Date/Time: Fri, 17 Jan 2025 06:00:11 +0000
CQG Encryption Stream Errors & Disconnects
View Count: 927
[2017-12-08 00:19:00] |
User75002 - Posts: 117 |
Hello, Since Tuesday (12/5), I have been getting disconnects with the following error. This seemed to start after upgrading from 1652(which didn't have the issue). I upgraded to 1656 and 1659 on 12/5 and noticed the issue later that day. My log only goes back to 12/5, but has occurred multiple times a day since. Prior to 1659, I do not recall having any random disconnects. CQG WebSocket socket (2751) | Encryption stream error encountered when processing received data. Failed to read incoming encrypted data from the incoming binary I/O stream. error:140E0197:SSL routines:SSL_shutdown:shutdown while in init | 2017-12-07 19:01:05 CQG WebSocket socket (2751) | Initiating close of socket by core. | 2017-12-07 19:01:05 CQG WebSocket | Network socket for WebSocket has been closed by remote side. | 2017-12-07 19:01:05 CQG WebSocket socket (2751) | Shutdown started. Waiting for graceful close. | 2017-12-07 19:01:05 CQG FIX Trading | WebSocket closed. | 2017-12-07 19:01:05 Connection to the external service has been lost. | 2017-12-07 19:01:05 CQG FIX: DisconnectFIX called. | 2017-12-07 19:01:05 CQG FIX: Sending a Logout message. | 2017-12-07 19:01:05 CQG FIX Trading | Disconnected. | 2017-12-07 19:01:05 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-07 19:01:05 CQG WebSocket socket (2751) | Received socket Close event. | 2017-12-07 19:01:05 CQG WebSocket socket (2751) | Still waiting for graceful close or receive error. | 2017-12-07 19:01:05 CQG FIX: Received a Logout message. Text = NormalLogoutInitiatedByCounterparty | 2017-12-07 19:01:05 CQG FIX socket (2750) | Initiating close of socket by core. | 2017-12-07 19:01:05 CQG FIX: Disconnected. | 2017-12-07 19:01:05 CQG FIX socket (2750) | Shutdown started. Waiting for graceful close. | 2017-12-07 19:01:05 CQG FIX socket (2750) | Socket gracefully closed by remote side. | 2017-12-07 19:01:05 CQG FIX socket (2750) | Closed. | 2017-12-07 19:01:05 Thank you! |
[2017-12-08 02:08:18] |
This thread actually confirms that apparently Open SSL which Sierra Chart uses does apparently have a bug in SSL_shutdown. We are removing the call to that for good. We will have to contact Open SSL about this. We are putting out a new release in about 15 minutes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-08 03:41:45
[2017-12-08 02:11:11] |
Version 1652 will be out in about 10 minutes.
