Date/Time: Fri, 17 Jan 2025 05:59:02 +0000
Hiding / Cancel study directly from the chart
View Count: 947
[2017-12-07 20:24:58] |
User136422 - Posts: 33 |
Hi Support It would be great have the possibility to hide or cancel a study directly from the chart, maybe from the chart value windows, whitout opening the study window every time. Don't know if this could be implemented natively in the platform or trought a new study. thanks |
[2017-12-07 20:37:44] |
This can be done. Refer to: Chart Studies: Hiding and Showing Study Directly from Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
