Date/Time: Fri, 17 Jan 2025 15:08:05 +0000
Camarilla Pivot Points / Formula 5 / Incorrect
View Count: 2209
[2017-12-07 17:23:10]
User371906 - Posts: 141
I am using Camarilla Pivot Points using formula 5 as stated in this post (below) and with the indicator provider by Sierra engineering (Pivot Points Formula 5.StdyCollct)
But the pivot don't align at the correct levels, please see attached comparison picture (left example is correct and right side Sierra chart with incorrect pivot lines)
Can you please give me an idea what might be causing it to miss align the pivot lines?
Thanks You
Regards
g
The first step is to add one of the Pivot Points studies to the chart:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies
The Camarilla Pivot Points are determined by Formula Type 5, as explained here:
http://www.sierrachart.com/index.php?page=doc/PivotPoints.html#Formula_5
To get these Pivot Point lines in either the Pivot Points – Daily or Pivot Points – Variable Period studies, you need to set the value of the Formula Type Input to 5 in the Settings window for the study. Refer to:
http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#SettingsandInputsTab
imageCamarilla comparison.JPG / V - Attached On 2017-12-07 17:20:06 UTC - Size: 251.61 KB - 642 views
attachmentPivot Points Formula 5.StdyCollct - Attached On 2017-12-07 17:20:23 UTC - Size: 9.4 KB - 477 views
[2017-12-07 18:48:02]
We can only refer you to the documentation here about this:
Pivot Points are not Accurate or are Different
Run through the calculations manually using the formula documented here:
And see what you determine.
Date Time Of Last Edit: 2017-12-07 18:48:34
[2017-12-17 07:51:43]
I have tried everything on the describe link sent but cant get even close to having Camarilla pivot points to come close to were they should.
Is there anything else I can try to make it work?
Please let em know.
Regards
g
[2017-12-18 22:01:52]
You need to refer to the section here about this:
Pivot Points are not Accurate or are Different: Manual Calculation for Verification of Data and Formulas
[2017-12-19 03:38:27]
Morning,
I have gone over every single point in the referenced link you sent me but once again I am unable to make the Camarilla pivots points read correctly.
Is there a log I can send you so perhaps you can see that it doesn't seem to correct to the right pivot lines?
If there anything else I can do to make it work correctly?
Please let me know
Regards
g
[2017-12-19 03:51:30]
And what did you learn by going through the exercise documented in?: Manual Calculation for Verification of Data and Formulas
You must have learned something and be able to express some specific data to us and be able to help us understand what the problem is. Only you are in a position to tell us what the problem is rather than us. You know what you want and why. We do not know.
You say the values are not right. Why? Tell us why. If you cannot tell us why, you are going to go nowhere with further communication to us.
Date Time Of Last Edit: 2017-12-19 03:53:19
[2017-12-19 03:52:52]
The prior post has been updated.
