Date/Time: Fri, 17 Jan 2025 05:54:42 +0000
Problem loading month
View Count: 865
[2017-12-07 14:16:06] |
User104854 - Posts: 457 |
I just added a chart to my chartbook and I want to load the December 2017 NQ (NQZ7). When I do this it keeps on putting it to NQH8 which is not what I want yet. I put continuous contract to 'none' but that isn't working. Can you help?
[2017-12-07 14:52:11] |
Got it fixed. Disregard. Thanks.
[2017-12-07 19:16:16] |
Make sure this is unchecked: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
