Date/Time: Fri, 17 Jan 2025 05:53:28 +0000
Continuous Futures Contract - Volume Based Rollover
View Count: 2056
[2017-12-07 12:39:05] |
User956467 - Posts: 30 |
I have "Automatically Rollover Futures Symbol" and "Continuous Futures Contract - Volume Based Rollover" selected in Chart Settings. F.US.EPZ17 automatically rolled over to H18 (March 18) this morning but volume is much higher in Z for at least another day. Volume is greater in Z right now (Thursday morning) and yesterday (Wednesday). This is the same for YM, ENQ and RTY. They all have rolled over without volume being higher. Can SC rollover futures contracts based on actual volume? Thank you! |
[2017-12-07 19:08:42] |
Do not use the Automatically Rollover Futures Symbol setting. You need to understand how that setting works: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) It is not based on volume. To get a notice to rollover based on volume, refer to: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
