Date/Time: Fri, 17 Jan 2025 07:21:48 +0000
Trading Chart DOM
View Count: 2178
[2017-12-07 09:45:29] |
User22414 - Posts: 66 |
After system crash my settings were broken. I could not do everything again as usual. 1) In the Charttrade DOM, the buy and sell column now shows red numbers (apparently the sales), which I do not need and find annoying. 2) The red buy or sell order and the green associated attachet order were previously pegged directly to the left of the Buy-Charttrade DOM column. Now I have a long line all over the chart to the far left and there the red buy or sell order and the green attachet order How / where can I restore my usual settings? |
[2017-12-07 11:06:53] |
In addition to above: I miss the display of the selected order price in the scale colum
[2017-12-07 19:51:50] |
1. You can configure the Chart/Trade DOM columns following the instructions here: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) 2. Enable this option: Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu) In addition to above: I miss the display of the selected order price in the scale colum For this, use the Chart Values tool while submitting an order:Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-12 18:36:18
[2017-12-12 16:09:50] |
Hej I find under the given link no indication of my problem. You did not understand me. So again: I do not want to adjust the size of the tading chart DOM columns, but the location of the 1) For example, sales order with the text: S / Lmt / 163.54 / Open / 0 / 1 / x 2) The stoporder with the text: B / Stop / 16.58 / Child-Client / 0/0 / x Both are located on the far left. But it should be, like the Tading Chart DOM located on the right side of the chart; just an to the left line of the buy column of the Tading Chart DOM. At the same time the scale should show the value for example: Sale 163.54 and 163.58 for the stop. Best Regards Helmut Hey Did you read my message and understood what my really problem is? If not then please contact me. If you do not have anyone who understands, then you should contact MAX or should I tell him all about it? He knows how to do that, because he has already changed it to personal on my PC. BR Helmut |
[2017-12-12 18:57:03] |
Yes we understand and we gave you the relevant documentation. You need to go to the chart and enable: Chart >> Chart Settings >> Advanced Settings >>Align Trade Drawings Text to Right At the same time the scale should show the value for example: Sale 163.54 and 163.58 for the stop.
For this, use the Chart Values tool while submitting an order:Chart Drawing Tools: Chart Values/Crosshair Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-12 18:57:16
[2017-12-12 19:33:06] |
finally ... thank you very much ... beautiful holidays and successful 2018 Helmut |
