Date/Time: Fri, 17 Jan 2025 05:59:39 +0000
Chart Scan!
View Count: 1035
[2017-12-07 04:01:32] |
User22591 - Posts: 133 |
Does Sierra have a chart scanner? If you do where san I find it?
[2017-12-07 04:19:18] |
Yes. Refer to the documentation here: Study/Chart Alerts And Scanning: Scanning for Alert Condition Across Multiple Symbols Also make sure you update to version 1659 when using this. A lower level problem has been resolved related to it. Refer to: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
