Date/Time: Fri, 17 Jan 2025 05:58:44 +0000
Import
View Count: 784
[2017-12-06 17:28:42] |
User39772 - Posts: 311 |
Hello, I try to import a file with the following format via Edit->Imort ... : 2017/01/01, 01:01:01, 100.0000 2017/01/01, 01:01:02, 102.7219 2017/01/01, 01:01:03, 104.6416 2017/01/01, 01:01:04, 106.7830 2017/01/01, 01:01:05, 105.2061 2017/01/01, 01:01:06, 100.1609 2017/01/01, 01:01:07, 100.2125 2017/01/01, 01:01:08, 100.8657 2017/01/01, 01:01:09, 101.6117 2017/01/01, 01:01:10, 102.8749 2017/01/01, 01:01:11, 102.9552 2017/01/01, 01:01:12, 105.3059 2017/01/01, 01:01:13, 107.8980 2017/01/01, 01:01:14, 108.2288 2017/01/01, 01:01:15, 107.4076 2017/01/01, 01:01:16, 109.1641 2017/01/01, 01:01:17, 106.8610 2017/01/01, 01:01:18, 107.6565 2017/01/01, 01:01:19, 109.7794 2017/01/01, 01:01:20, 106.8988 2017/01/01, 01:01:21, 108.0531 2017/01/01, 01:01:22, 108.9293 2017/01/01, 01:01:23, 107.2203 2017/01/01, 01:01:24, 106.3867 2017/01/01, 01:01:25, 108.2512 2017/01/01, 01:01:26, 109.2649 2017/01/01, 01:01:27, 108.1915 2017/01/01, 01:01:28, 111.6921 2017/01/01, 01:01:29, 113.6250 2017/01/01, 01:01:30, 112.6283 2017/01/01, 01:01:31, 115.3483 2017/01/01, 01:01:32, 113.4668 2017/01/01, 01:01:33, 113.1298 2017/01/01, 01:01:34, 115.1327 2017/01/01, 01:01:35, 114.6437 2017/01/01, 01:01:36, 115.9708 2017/01/01, 01:01:37, 114.5386 2017/01/01, 01:01:38, 116.6096 2017/01/01, 01:01:39, 119.8882 2017/01/01, 01:01:40, 118.9170 etc. (file is much more longer). I see a blue progress bar that seems to indicate that SC is loading the file, but I see nothing on the chart and nothing in the Edit-Tool (all fields are empty). Any hints would be helpful. |
[2017-12-06 18:37:49] |
This data format looks fine. However, you are running an older version of Sierra Chart. You must update the current version for the most up-to-date import functionality: Software Download: Fast Update You are not going to see any chart until the time the import is complete. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 18:38:13
[2017-12-06 19:48:36] |
Thank you: I updated to 1659. Still only an empty chart visible but now I can see the date in the intraday editor. Data is stored in a file named text.txt as shown above. Message Log says: TEXT 1 Min #4 | Reloading chart. | 2017-12-06 14:44:53 TEXT 1 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\Tradingtools\SierraChart\Data\text.scid | 2017-12-06 14:44:53 Currently I'm in free mode, could this be the reason ? |
[2017-12-06 20:43:36] |
Attach the text file so we can test.
