Date/Time: Fri, 17 Jan 2025 06:05:34 +0000
Candle stick wicks width odes not change with outline adjustments
View Count: 1005
[2017-12-06 17:07:10] |
User360283 - Posts: 506 |
I am trying to have the candle stick wicks show up better. I have increased the candle stick outline width but the wicks do not change accordingly. Help Thanks |
[2017-12-06 17:21:28] |
Note Chart is Renko 5-4-1.
[2017-12-06 19:33:34] |
You need to adjust the width settings for Bar High-Low Down/Up. Refer to: http://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 19:33:47
