Date/Time: Fri, 17 Jan 2025 05:50:13 +0000
Trade Order Matching Error
View Count: 1461
[2017-12-06 10:14:28]
aydex - Posts: 110
Followed the instructions here
Attached Orders: Order Quantity Matching
but once the order is to be filled (no fill occurs,) the green match notification goes red, and seeing this error
Trade Order Error: The order quantity for the Parent is 1 and this is less than the total order quantity of 2 for the Attached Orders. Adjust the order quantities so the parent is greater or equal to the Attached Orders.
I am using the supplied "2TargetsWithCommon Stop" twconfig, with no mods except to change Main window qty to 2.
I have set
Allow Multiple Entries in Same Direction
to Yes in the spreadsheet study.
Are there any other limiters to the qty?
[2017-12-06 10:23:30]
This just means you cannot use 2 Target orders if the parent order quantity is 1. Remove one of the Target orders. This is very simple. This is not hard to understand.
Date Time Of Last Edit: 2017-12-06 10:23:49
[2017-12-06 10:38:22]
aydex - Posts: 110
Sorry I wasn't clear, to restate:
Changed Main window qty to 2, to match the two targets.
Assumed that increasing the Main window qty is an alternative to decreasing one of the Target orders?
Wanting 2 target orders,
just like this example
Attached Orders: Multiple-Bracket Example
(and in "2TargetsWithCommon Stop")
Would understand if during the setup its was red, but it doesn't go red until the fill is expected.
[2017-12-06 18:50:40]
You need to set the quantity of 2 on the Spreadsheet Sheet itself:
http://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#CellJ26
It sounds like it is set to 1 and when the order is submitted from the Spreadsheet, is when the Trade Window updates.
