Date/Time: Tue, 26 Nov 2024 00:29:06 +0000
Dark theme
View Count: 1832
[2017-12-06 09:04:06] |
grantx - Posts: 244 |
It would be great if you could enable an option to switch between a light and dark theme to the platform. Not just the charts. The entire platform skin. |
[2017-12-07 01:55:54] |
User791167 - Posts: 22 |
+1 on this request.
[2017-12-07 02:56:50] |
What we do plan to add is the capability to switch between different color and graphics configurations easily.
[2024-01-19 13:14:20] |
mrseho - Posts: 25 |
+1
