Date/Time: Fri, 17 Jan 2025 05:51:53 +0000
Footprint imbalance
View Count: 2579
[2017-12-06 08:33:48] |
User15378 - Posts: 45 |
Hi there Sierra I was looking on multi charts blog for imbalance recommendations for my market and i see they mention "min diff" here is what they say- "The Min Diff value is volume and represents the minimum volume difference required to be considered an imbalance. For higher volume contracts we recommend larger values, and for lower volume or volatile contracts we recommend smaller values." I was wondering is there a setting for this on Sierra and if so what is i called or is it needed? Cheers |
[2017-12-06 18:20:07] |
Yes of course. There is an Input for this. Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#Input_BidAskMinimumVolumeCompareThreshold Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
