Date/Time: Fri, 17 Jan 2025 06:06:26 +0000
Tape reading
View Count: 2916
[2017-12-06 04:56:54] |
User740266 - Posts: 26 |
May I ask is there any possible way to buy and import the real time real tick data into a mode of tape reading window in the sierra chart for hsi futures, commodity futures and forex ?
[2017-12-06 05:05:59] |
It sounds like you want a real-time data feed for these markets? Yes, this is supported.
[2017-12-06 18:21:30] |
So if you want this real-time data you will need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed However ,if you want the real-time Hong Kong futures data, since you are in Hong Kong that is only available if you are with one particular trading educator. Let us know if you want more information about that. And here is the documentation for the Time and Sales window: http://www.sierrachart.com/index.php?page=doc/TimeandSalesWindow.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-06 18:22:40
