Date/Time: Fri, 17 Jan 2025 14:58:36 +0000
Rithmic Frankfurt Server
View Count: 2372
[2017-12-05 21:59:40] |
nosast2 - Posts: 73 |
Rithmic has recently added a server in Frankfurt to the network and I'm getting better latency times compared to the Europe gateway when measuring in RTrader Pro. I'm located in Germany and trading Eurex products such as FBGL and FESX. Could this new server/gateway also be added to the dropdown in Sierracharts? Rithmic suggests to use this gateway for trading Eurex products as per youtube video at 1:19:00 https://youtu.be/uJEjiTJuoPo Attached is a screenshot from the login window of RTraderPro. Thanks in advance Norman Date Time Of Last Edit: 2017-12-05 22:00:34
2017-12-05_22-51.png / V - Attached On 2017-12-05 21:59:13 UTC - Size: 305.3 KB - 484 views |
[2017-12-06 06:41:02] |
We have contacted Rithmic for the connection details.
[2017-12-07 20:44:13] |
Great thanks!
[2017-12-08 05:12:52] |
We have the connection details. Just give us a few days to get this set up.
[2017-12-18 21:31:52] |
I see the Frankfurt server now in the connection details but still can't log in to this server. Europe and US are working fine but Frankfurt the connection request timed out. Using R-Trader I can connect to Frankfurt so the problem does not seem to be related to the account. Please see Log: Rithmic Trading | Port for executable: 51067 | 2017-12-18 22:28:15 Listening socket (1312). Port 51067 | Closed. | 2017-12-18 22:28:15 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-12-18 22:28:15 Rithmic Trading | Bridge process is running. | 2017-12-18 22:28:17 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51067 | 2017-12-18 22:28:17 DTC Client socket (6) | Creating socket. | 2017-12-18 22:28:17 DTC Client socket (6) | Connecting to IP: 127.0.0.1. | 2017-12-18 22:28:17 Rithmic Trading | Connected to server. | 2017-12-18 22:28:17 Rithmic Trading | Starting socket receive thread. | 2017-12-18 22:28:17 Rithmic Trading | Sending Encoding Request to server | 2017-12-18 22:28:17 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-12-18 22:28:17 Rithmic Trading | Sending logon request message. | 2017-12-18 22:28:17 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-12-18 22:28:17 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-12-18 22:28:17 Rithmic Trading | Message from server: Connecting to Rithmic 01 Frankfurt server. | 2017-12-18 22:28:17 Service connection timed out. Will disconnect and retry. | 2017-12-18 22:30:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2017-12-18 22:30:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2017-12-18 22:30:15 DTC Client socket (6) | Initiating close of socket by core. | 2017-12-18 22:30:15 Rithmic Trading | Disconnected. | 2017-12-18 22:30:15 DTC Client socket (6) | Shutdown started. Waiting for graceful close. | 2017-12-18 22:30:15 DTC Client socket (6) | Socket gracefully closed by remote side. | 2017-12-18 22:30:35 DTC Client socket (6) | Closed. | 2017-12-18 22:30:35 And the Log to the European server in Ireland (which works fine): Rithmic Trading | Port for executable: 51088 | 2017-12-18 22:32:38 Listening socket (1332). Port 51088 | Closed. | 2017-12-18 22:32:38 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2017-12-18 22:32:38 Rithmic Trading | Bridge process is running. | 2017-12-18 22:32:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 51088 | 2017-12-18 22:32:40 DTC Client socket (11) | Creating socket. | 2017-12-18 22:32:40 DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2017-12-18 22:32:40 Rithmic Trading | Connected to server. | 2017-12-18 22:32:40 Rithmic Trading | Starting socket receive thread. | 2017-12-18 22:32:40 Rithmic Trading | Sending Encoding Request to server | 2017-12-18 22:32:40 Rithmic Trading | Setting DTC encoding to Binary VLS | 2017-12-18 22:32:40 Rithmic Trading | Sending logon request message. | 2017-12-18 22:32:40 Rithmic Trading | Message from server: Starting the connection process to data and trading service. | 2017-12-18 22:32:40 Rithmic Trading | Message from server: Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2017-12-18 22:32:40 Rithmic Trading | Message from server: Connecting to Rithmic 01 Europe server. | 2017-12-18 22:32:40 Rithmic Trading | Message from server: Server Alert: Market Data Connection Opened | 2017-12-18 22:32:40 Rithmic Trading | Message from server: Server Alert: Trading System Connection Opened | 2017-12-18 22:32:41 Rithmic Trading | Message from server: Server Alert: Market Data Connection Login Complete. Result text: "ok" | 2017-12-18 22:32:41 Rithmic Trading | Message from server: Server Alert: PnL Connection Opened | 2017-12-18 22:32:41 Rithmic Trading | Message from server: Server Alert: PnL Connection Login Complete. Result text: "ok" | 2017-12-18 22:32:42 Rithmic Trading | Message from server: Server Alert: Trading System Connection Login Complete. Result text: "ok" | 2017-12-18 22:32:42 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Opened | 2017-12-18 22:32:42 Rithmic Trading | Message from server: Server Alert: Intraday History Connection Login Complete. Result text: "ok" | 2017-12-18 22:32:42 Rithmic Trading | Received logon response. | 2017-12-18 22:32:43 Rithmic Trading | Server Name: SC DTC Bridge. | 2017-12-18 22:32:43 Rithmic Trading | Server protocol version: 8. Client protocol version: 8 | 2017-12-18 22:32:43 Rithmic Trading | Successfully connected. IB='AMP', Firm='AMPClearing'. | 2017-12-18 22:32:43 Rithmic Trading | Trading is supported. | 2017-12-18 22:32:43 Rithmic Trading | Order cancel and replace is supported. | 2017-12-18 22:32:43 Rithmic Trading | OCO Orders supported. | 2017-12-18 22:32:43 Rithmic Trading | Connected to data and trading server. | 2017-12-18 22:32:43 Date Time Of Last Edit: 2017-12-18 21:34:14
[2017-12-18 22:55:43] |
We noticed that as well but did not really know the reason. We need to ask Rithmic about this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-22 06:25:47] |
This is now resolved in the latest version of Sierra Chart, 1674: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-22 06:26:54
