Date/Time: Fri, 17 Jan 2025 05:56:58 +0000
Replicating custom levels from one chart to another one
View Count: 1204
[2017-12-05 21:04:26] |
s291117 - Posts: 28 |
Hello Support, I wish to know if it is possible to replicate a specific selection of studies from one chart to any other one, from the same chartbook or to other chartbooks ? If i take this example from a Volume profile chart: https://gyazo.com/a7aa21f750cbc2fe96cc9fe6eb84a7ed I have to select each study, choose as defaut, then go to the destinatory chart, reselect the same study to have it integrated. This take an amaizing amount of time ! I wish that were a feature allowing to save all the studies or a specific selection of them, save them as a profil, that one could recall easily at any moment. Thanks for your precisions, A. |
[2017-12-06 00:18:32] |
Refer to Study Collections: Study Collections Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-07 07:55:27] |
Hello Support, i know about StudyCollections, i have now various of them. My request deals with specifically the levels (Daily OHLC, VWAP, SD, TPO POC Daily, Weekly, Monthly, ecc.) It seems that there is no way to just keep a selection of them, save them as an external files, to be recalled as a profil of levels on any chart. The possibility to import a thin selection of levels to a naked chart or at the contrary all the possible levels that were previously imported, could be an efficient tool to see the price action according to specific levels, and switch from one configuration to another. Thanks for your attention. |
[2017-12-07 18:07:52] |
Study Collection does meet your requirements. We recommend reading through that entire page again: Study Collections It does do what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
