Date/Time: Fri, 17 Jan 2025 05:47:34 +0000
Market Depth Hist. Gragh
View Count: 1692
[2017-12-05 20:49:34]
conr - Posts: 204
Downloaded 1656 Sunday, charting ES. As of yest. not getting any shading. Friday was working fine.
[2017-12-05 21:23:41]
Refer to the instructions here for this:
Market Depth Historical Graph: Market Depth Historical Graph Not Displaying
[2017-12-05 23:23:28]
conr - Posts: 204
Prior to submitting the post I went through all those steps except for the very last one. One thing I do notice and it looks like a setting issue for one of the studies in region one. Prior to this problem I was not able to see the horizontal grid in the depth field. Now it is there.
[2017-12-05 23:40:04]
So is the problem now resolved?
[2017-12-05 23:47:25]
conr - Posts: 204
No
[2017-12-06 00:17:15]
So do you see the market depth data in File >> Open Market Depth Data? First go to the chart and then select that command.
Did you try deleting the market depth data file? Normally this should not be necessary.
[2017-12-06 00:20:28]
Try resetting the study back to the default settings following these instructions here:
Chart Studies: Resetting Default Study Settings For an Individual Study
Also refer to the prior post as well.
Date Time Of Last Edit: 2017-12-06 00:20:36
[2017-12-06 14:24:18]
conr - Posts: 204
I've done everything except rename. Before I take that step I want to make you aware that I have another es chart where it is working fine. I attached 2 images of what I noticed and mentioned in post 3. The study that is working properly does not show the horz. grid lines.
imagees.PNG / V - Attached On 2017-12-06 14:23:44 UTC - Size: 104.96 KB - 357 views
imagees2.PNG / V - Attached On 2017-12-06 14:23:56 UTC - Size: 88.47 KB - 325 views
[2017-12-06 15:36:10]
conr - Posts: 204
Problem is solved. I duplicated the chart and that one worked. Question. How do I move vol by price and market depth hist graph to the left of the DOM graph?
[2017-12-06 19:29:49]
For the Market Depth Historical Graph, reduce the amount of this Input:
Market Depth Historical Graph: Percentage Of Fill Space To Display Market Depth Quantity Rectangles In
For the Volume by Price study use this Input:
Volume By Price Study: Do Not Overlap DOM Graph
We think the problem you had probably had to do something with the Market Depth Historical Graph Input settings.
[2017-12-07 15:01:41]
conr - Posts: 204
Shut down and restarted sierra for es rollover and back to the problem. Duplicated the chart and that one worked fine. As mentioned above look at the missing horizontal grid lines in properly working chart.
imagees1.PNG / V - Attached On 2017-12-07 15:01:05 UTC - Size: 92.83 KB - 321 views
imagees2.PNG / V - Attached On 2017-12-07 15:01:15 UTC - Size: 121.08 KB - 326 views
[2017-12-07 19:14:27]
Attach the Chartbook following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
It looks like it is chart #35 with the issue.
Could be some kind of Windows 10 issue. But that would seem unlikely.
Date Time Of Last Edit: 2017-12-07 19:14:54
[2017-12-07 19:27:36]
conr - Posts: 204
File attached
attachmentES.cht - Attached On 2017-12-07 19:27:22 UTC - Size: 3.06 MB - 449 views
[2017-12-07 20:33:34]
The Market Depth Historical Graph does appear for us with chart number 35:
http://www.sierrachart.com/image.php?Image=1512678794525.png
That is a very complicated chart. We would recommend removing all studies other than the Market Depth Historical Graph and make the main price graph visible.
And see if that makes a difference.
Date Time Of Last Edit: 2017-12-07 20:35:07
[2017-12-07 20:44:35]
conr - Posts: 204
Removed everything and still the same.
