Date/Time: Sun, 24 Nov 2024 04:27:27 +0000
Won't populate Available Symbols page...
View Count: 1450
[2013-09-16 14:52:44] |
maxpi - Posts: 181 |
non CLR 1025, just built a nice Lenovo laptop/Win7, fresh install of software, one instance of SC... I can connect to my Barchart data account and pull up a chart of NQZ13 for example. If I select File - Find Symbol the page that displays all the symbols available from Barchart opens up but nothing appears in it. Nothing shows in the log... I'm guessing that maybe something is wrong at Barchart's end, it would be rare, but it can happen, but maybe not?
[2013-09-16 20:01:51] |
Go to Global Settings >> Symbol Settings. Press the Update From Server button. Wait for the Symbols list to fill.
