Date/Time: Thu, 16 Jan 2025 23:37:15 +0000
Spreadsheet formulas are Blank after update
View Count: 778
[2017-12-05 16:31:59] |
ForgivingComputers.com - Posts: 987 |
Today I was told by Infinity Futures that I needed to update my application. I completed the process and now that I am on version 1658, all of my spreadsheet formulas are missing. If I create a new chart, attach a spreadsheet for trading, put 1's in K3 and M3, and then save all, the cells are blank after re-opening the chart book. This is incredibly inconvenient. None of my spreadsheets work now. HELP! If there is a new setting that is causing this, please let me know. I hope my files are OK and the application is not reading them correctly. |
[2017-12-05 17:24:13] |
Note that after reverting back to 1651 or 1605, the spreadsheets are fine.
[2017-12-05 18:00:53] |
We can see that 1658 does have a problem with the opening of Spreadsheets. We apologize for that. We have removed that as the main release. For now just go back to version 1656: Software Download: Software Rollback Procedure If necessary there are backup spreadsheet files in the Backups subfolder in the folder that Sierra Chart is installed to. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-05 18:05:08
[2017-12-05 19:23:15] |
This issue is now resolved in version 1659.
