Date/Time: Thu, 16 Jan 2025 23:43:03 +0000
VWAP- Rolling study - showing instability across instances
View Count: 864
[2017-12-04 18:19:46] |
User299392 - Posts: 216 |
With the same 5-min chart for the same symbol, same exact number of days loaded up for the symbol, same exact study settings and even the scaling is the same - it produces 2 different values when opened in 2 different instances. Symbol in question here was NQ-December contract. Please help. |
[2017-12-05 12:45:51] |
Any luck looking at this?
[2017-12-05 21:05:07] |
You must follow through the procedure here for this to determine what the problem is and resolve: Chart Studies: Resolving Study Differences Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-05 21:05:27
