Date/Time: Thu, 16 Jan 2025 23:38:25 +0000
Flex Renko broken on GDAXI this morning.
View Count: 1077
[2017-12-04 08:16:55] |
gomifromparis - Posts: 244 |
Sorry, another Renko issue. Seems GDAXI had a bad tick that ruined the flex renko, it won't create another bar. |
RENKOGDAXI.png / V - Attached On 2017-12-04 08:16:50 UTC - Size: 50.85 KB - 297 views |
[2017-12-04 08:19:13] |
We are checking on this.
[2017-12-04 08:36:57] |
This is just a comparison issue because the symbol trades in values with precision to .01 or sometimes even .001. For now set Chart >> Chart Settings >> Price Display Format to .01. This will solve the problem for now until we work out a solution later today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-04 09:33:03
[2017-12-05 05:00:01] |
This is resolved in version 1658. It was basically a floating-point comparison issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
