Date/Time: Sun, 24 Nov 2024 04:21:39 +0000
Too much data in the directory sierra chart (program files)
View Count: 1722
[2013-09-16 11:54:15]
draz - Posts: 10
I noticed that my catalog (Sierra chart) is growing and growing size,,, this is now more than 10 GB, I noticed that the file DATA I have a lot of small files, probably graphs of some instruments that I've seen before, not now. . What should I do to stop raising SC GB software program files directory that is for me to get the old files that do not use anymore?
[2013-09-16 12:10:25]
draz - Posts: 10
This will better understand
imageold data.PNG / V - Attached On 2013-09-16 12:09:47 UTC - Size: 48.53 KB - 490 views
imageused space from folder DATA.PNG / V - Attached On 2013-09-16 12:09:56 UTC - Size: 31.3 KB - 489 views
[2013-09-16 15:08:07]
draz - Posts: 10
much more data here
imagedata 10 gb.PNG / V - Attached On 2013-09-16 15:07:55 UTC - Size: 53.33 KB - 472 views
[2013-09-16 16:19:08]
You are able to delete any of the chart data files that you no longer use. Here are instructions:
http://www.sierrachart.com/index.php?l=doc/doc_ChartDataFiles.html#DeletingCharts
[2013-09-16 16:37:50]
draz - Posts: 10
Can I delete all file SCID? blue in the DATA folder?
[2013-09-16 19:32:03]
Yes of course. You can delete any files in the Data folder that you want to. There is no problem with this.
