Date/Time: Fri, 17 Jan 2025 07:29:04 +0000
Daily OHLC lines for pit and globex session
View Count: 2444
[2017-12-03 12:29:46] |
User164231 - Posts: 278 |
Hi, How do I split the OHLC vertical lines for day and night session? Also, is it possible to project historical OHLC lines all the way to the right? Thanks. |
[2017-12-03 13:07:41] |
We need to understand what you mean by the OHLC vertical lines. Are you referring to the ordinary OHLC chart bars? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-04 02:14:58] |
Hi, I am referring to the study "Daily OHLC" vertical lines. I would like to separate OHLC vertical lines on day (morning to afternoon) and night (evening to midnight) session. I attach image of a default one which is only showing the full day session (morning to night). |
Private File |
[2017-12-05 04:47:12] |
Really it is recommended that you use 2 instances of the High/Low for Time Period study to accomplish this: High/Low for Time Period Each one configured to the particular time range that you want. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-12 02:25:05] |
why I didn't think of that!
