Date/Time: Sat, 01 Mar 2025 11:33:51 +0000
[Programming Help] - sc.TransparencyLevel
View Count: 1268
[2017-12-03 11:14:10] |
binaryduke - Posts: 378 |
Hi SierraChart I note this ACSIL variable but it is not used in any study in the /studies folder. Can this be used to access the 'Transparency Level' input for a subgraph? Thx BD. |
[2017-12-04 09:01:39] |
This is documented here: ACSIL Interface Members - Variables and Arrays: sc.TransparencyLevel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-10-02 09:01:45] |
User428450 - Posts: 5 |
Hi SierraChart Can you give an example of setting the Transparency level in ASCIL for a specific Subgraph, for example; xyz.Name = "Histogram"; xyz.DrawStyle = DRAWSTYLE_TRANSPARENT_FILL_TO_ZERO; xyz.PrimaryColor = RGB(200,0,0); xyz.TransparencyLevel = 70; <-------- Thx Date Time Of Last Edit: 2021-10-02 09:02:31
