Date/Time: Thu, 16 Jan 2025 23:42:11 +0000
Renko bar settings
View Count: 1620
[2017-12-02 16:14:15]
User466737 - Posts: 22
I see the following inputs mentioned in your documentation for Renko bars. Can't seem to locate it under chart settings, where can I find the following two settings?
Use High/Low Values Instead of Last Value
Ignore Latest Underlying Bar until Close
Thanks,
S
[2017-12-02 19:03:24]
Those are for the old Renko studies which are unsupported.
Here is the Renko Chart Bar documentation:
Renko Bar Charts
[2017-12-03 01:49:08]
Those Renko studies can be accessed through Analysis >> Studies >> Add Custom Study >> Sierra Chart Custom Studies and Examples.
But if you have any problems with them or limitations, this is not something we are going to help with.
Date Time Of Last Edit: 2017-12-03 01:49:25
