Date/Time: Sun, 24 Nov 2024 02:05:41 +0000
TradeGuider VSA Study indicator description window
View Count: 3070
[2013-09-16 09:16:24] |
User96105 - Posts: 113 |
Hi, I've started using this Study recently and whilst the Bar Summary window displays correctly, I am not seeing the indicator description window which should appear when using the cross-hairs and right clicking when a over VSA "triangle". Could this window be blocked by something? So far TradeGuider have not come back with a solution for this. Thanks Date Time Of Last Edit: 2013-09-16 09:19:00
[2013-09-16 09:27:10] |
We cannot comment on this, because this is not a feature of Sierra Chart. We do not know how they accomplish that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
