Date/Time: Fri, 17 Jan 2025 00:01:59 +0000
ZT continuous chart
View Count: 1150
[2017-12-01 13:25:34] |
cmb999 - Posts: 211 |
rollover chart seems broken for ZT H18. does not include Dec contract data (ends with Sep. contract). only when viewing ZT Z17 directly does chart include that history
[2017-12-01 14:00:57] |
Follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-12-03 23:11:17] |
i tried the instructions, every other symbol seem to work but ZT, http://www.sierrachart.com/image.php?Image=1512342591682.png edit: there were almost 100 contracts (going back 20 years) in the edit data dialog, so was hesitant to re-download all, but that fixed it. btw, not sure how to de-select all those contracts in the dialog, and only select one or two recent ones Date Time Of Last Edit: 2017-12-03 23:20:35
[2017-12-04 22:14:21] |
btw, not sure how to de-select all those contracts in the dialog, and only select one or two recent ones We can see there is no easy way. We will look into this.
