Date/Time: Thu, 16 Jan 2025 23:37:55 +0000
Is it ok to leave Sierra open all the time? How often should I restart?
View Count: 1022
[2017-12-01 12:57:04] |
User791167 - Posts: 22 |
I'm basically wondering if it's ok to leave Sierra running at all times? Is there anything I should be aware of in terms how often I should be restarting or clearing a cache of some sort? Thanks |
[2017-12-01 15:13:14] |
Yes you can leave it running all the time for even a year if you want.
[2017-12-01 15:56:33] |
Very good. Thank you
