Date/Time: Mon, 25 Nov 2024 02:52:51 +0000
QuoteBoard Visible Across Multiple Chartbooks
View Count: 1508
[2013-09-16 03:39:45] |
Futures Operator - Posts: 239 |
I keep the Quoteboard up on a separate monitor and want it always visible regardless of which chartbook I'm looking at. I've tried attach/detach window and always on top settings from the QuoteBoard but neither setting seems to work, if I change Chartbooks, the Quoteboard disappears to the background. How can I keep it visible across all Chartbooks?
Date Time Of Last Edit: 2013-09-16 03:40:05
[2013-09-16 04:02:14] |
Also a separate but related to the QuoteBoard issue is, after clicking on a symbol in the watchlist on the QuoteBoard, and clicking Settings, Set Chart Link, it sometimes takes a long time to load the set chart link settings box, or seems to 'hang' Sierracharts, unless/until the 'alt' key is pressed. On v1025, have not noticed this previously, and cpu load is very low, nothing unusual in log.
Date Time Of Last Edit: 2013-09-16 04:04:16
[2013-09-20 09:07:32] |
Can anyone help?
[2013-09-20 16:52:06] |
We will get back to you on this.
[2013-09-21 00:19:45] |
We will add an option to allow the Quote Board to be always visible no matter which Chartbook is active. It may be a while before we get to this. We do not see any problems with setting the Chart link through a Quote Board. That should work reliably. If not, it must be system specific. We recommend pressing the Escape key if you notice that the Chart Link window does not display. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-21 00:20:26
[2014-01-08 17:36:10] |
Any update on making Quote Board available across all chartbooks?
