Date/Time: Fri, 17 Jan 2025 00:05:46 +0000
EMA Shift Value
View Count: 767
[2017-12-01 08:40:25] |
User371906 - Posts: 141 |
Hello, Is it possible to set for a moving exponential average a shift number? I want to be able to set EMA 4 with shift 1 but in studies there is no field to be able to set this shift number. Thanks g |
[2017-12-01 19:07:04] |
It sounds like you want to use the Subgraph Displacement setting: Chart Studies: Subgraphs Tab >> Displacement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
