Date/Time: Sat, 18 Jan 2025 13:10:00 +0000
Full deph of market with Rithmic data feed
View Count: 3513
[2017-12-01 07:24:03]
TradingMarketProfile - Posts: 120
Now with rithmic, we suppose to get the full deph of market, everywhere there is a limit order, we suppose to be able to see it.
I n Bokkmap, we can it's ok but not with Sierra's DOM.
I added 500 level in deph market in chart settings but it's the same.
Can you tell me what to do to get this or it is not possible with Sierra chart ?
[2017-12-01 14:35:47]
Go to a chart for the symbol and select File >> Open Market Depth Window. Do you see the full market depth there?
If not, contact your broker to make sure your Rithmic account is authorized for the full market depth.
[2017-12-01 15:44:29]
the market deph is not better than the DOM
The first limit order at the bid in the deph of market is2634.25
but in the vertical DOM it's 2631.25
As you can see in bookmap i can see limit order under 2600 at the bid
It's the same broker and same data provider
we suppose to be able to see the full order book in any platform with Rithmic
https://gyazo.com/482ac679204579dbba6e612845cba1ea
https://gyazo.com/53a633725ddba4c82bfa9ccc6f9f2575
thanks
Date Time Of Last Edit: 2017-12-01 16:07:19
[2017-12-01 20:36:25]
We need you to follow our instructions. It is not helpful to us to provide other information. And we cannot look at screenshots on other websites because they do not display for us due to security measures.
We want you to go to a chart for the symbol, and select File >> Open Market Depth Window.
Position that market depth window over the chart and then select Edit >> Screen Images >> Upload Chart with Overlays.
Paste the link here.
Date Time Of Last Edit: 2017-12-01 20:37:42
[2017-12-01 23:24:52]
this is the link but you have nothing to compare
http://www.sierrachart.com/image.php?Image=1512170572603.png
http://www.sierrachart.com/image.php?Image=1512170789652.png
Date Time Of Last Edit: 2017-12-01 23:26:56
[2017-12-04 08:42:44]
This appears to be a limitation with the Rithmic API that we use. Really there is not much we can do about it at the moment. This will be looked into later on.
[2018-02-15 09:35:49]
User921942 - Posts: 16
I'm in the same case when will you do something?
[2018-02-20 12:20:21]
up !
