Date/Time: Thu, 16 Jan 2025 23:51:52 +0000
pivot points study with CTS T4
View Count: 956
[2017-12-01 00:25:36] |
User859795 - Posts: 51 |
hello, when i'm using Pivot Points Daily study with CTS T4 datafeed from AMP futures, the pivot and suppprt/resistance lines are showing abnormal numbers,for example on ES instead of .25 or .50 etc, i'm seeing numbers like .23, .88 and so on. If i'm using CQG data feed, all numerbers and lines are showing correct numbers - .25, .50, .75 Who can fix this? CTS? thank you, zolie |
[2017-12-01 05:03:55] |
You need to set this Input with the study to Yes: Pivot Points: Round to Tick Size Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
