Date/Time: Thu, 16 Jan 2025 21:58:42 +0000
Don't want ETH VWAP reset...
View Count: 1630
[2017-11-30 14:19:52] |
User629089 - Posts: 93 |
Hi, I'd like to have the study "Volume Weighted Average Price" for the ETH to not reset at any time. If under Chart Settings you have the session set up as 00:00:00 - 23:59:59, it resets at midnight. If you have it have it set up as 8:00 - 7:59:59 (for symbol CL) it resets at the RTH open. I look at both the RTH and ETH VWAP's as both are really important. I'm wondering if a continuous contract or something else could be used to resolve this... Thanks |
[2017-11-30 18:19:51] |
You just need to set the Start Date-Time Input for that study to where you want it to begin: Volume Weighted Average Price (VWAP) with Standard Deviation Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
