Date/Time: Thu, 16 Jan 2025 21:55:41 +0000
New Versions of Sierra Chart past 1650
View Count: 1055
[2017-11-30 13:59:29] |
doctor10 - Posts: 78 |
I have never had problems moving spreadsheet studies into a new version of sierrachart until now. This is extremely unsettling. Older versions get to work opening my .scss,.cht,scid associated with this project when I open the save file. New versions just hang endlessly at chart loading. Need a solution besides "use an older version" ASAP.
[2017-11-30 14:06:21] |
The only thing that I can think of that may be causing an issue but shouldn't be is that I use a two decimal offset in tick size to get down to a smaller renko resolution.
[2017-11-30 17:31:42] |
OK this might be related to Renko bars. Use the latest "Prerelease". Follow the instructions here: Software Download: Fast Update Make sure you update to the "Prerelease" Version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-30 17:31:58
[2017-11-30 17:52:46] |
Loaded up fine in pre-release 1656! Thank you! |
