Date/Time: Thu, 16 Jan 2025 22:04:28 +0000
Adding to menu a bar period type
View Count: 919
[2017-11-29 17:54:09]
bala - Posts: 74
I can add to the menu different time frames but these are time based. In addition can I add a range per bar standard type on the menu. The objective is to switch between a 5 min chart and a 2tick range per bar standard.
I am using two charts now and it's cumbersome.
[2017-11-29 18:53:13]
You need to use Control Bar buttons for this:
Control Bar: Custom Buttons for Intraday Chart Bar Period
