Date/Time: Thu, 16 Jan 2025 21:53:31 +0000
Market Depth histogram on DOM (1st column)
View Count: 1896
[2017-11-29 16:33:52] |
John Mc - Posts: 32 |
When I add the NQZ7 chart to the chartbook and open a dom for it nothing shows for the market depth histogram. Is there a way to get this to show?
[2017-11-29 18:02:55] |
The first thing is to determine if there is market depth data. Open the Market Depth window: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-30 17:58:04] |
When I add the NQZ7 chart to the chartbook and open a dom for it nothing shows for the market depth histogram (i.e. the first column). Is there a way to get data to show in this column? I checked and market depth data appears in the market depth window. |
[2017-11-30 18:31:47] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
