Date/Time: Thu, 16 Jan 2025 21:55:48 +0000
Simple Text Label in ACSIL?
View Count: 3595
[2017-11-29 11:21:32]
User799373 - Posts: 19
getting my head around ACSIL finally!
I'm trying to display a simple label with the value of the study I'm calculating.
I'm looking at the examples and it seems like a lot of code to display a simple label.
In another platform I would do something like:
say the study calculated = SMA
Addlabel("some text", SMA, some.color);
Is there a tutorial or an example showing a simpler usage of displaying a label on a chart?
Thank you!
[2017-11-29 19:00:20]
Refer to:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].LineLabel
[2017-11-29 20:12:02]
Thanks, if I understand correctly that is for displaying a studie's name/value in the same manner one would specify in the subgraph style section of an advanced study.
What I'm looking to do is display a series of labels much like the "Large Text studies" which is the examples I was looking at, which seem verbose, but if that's the way to do it, I guess I'll do that.
I believe what I'm looking for is this:
ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle
sc.Subgraph[].DrawStyle and in particular this DRAWSTYLE_TEXT, is this correct?
I'm porting a study in which I have various values displayed as text labels and which change colors dynamically. The values of this studies will not be displayed as subgraphs.
Thanks!
[2017-11-29 22:35:08]
The Text Draw Style is documented here:
Chart Studies: Text (ACSIL: DRAWSTYLE_TEXT)
This does not really sound like what you want. The other method is documented here and requires using the Text drawing tool:
Using Drawing Tools From an Advanced Custom Study
[2017-11-29 22:46:39]
Yes, I believe this is what I'm looking for!
Thank you!
