Date/Time: Thu, 16 Jan 2025 21:54:36 +0000
Error message: how to ...
View Count: 1317
[2017-11-29 11:02:54] |
s291117 - Posts: 28 |
sir, excuse me to bother you but i have a slight problem: every 10 secondes appear the same message: https://gyazo.com/84a5708f27a560c666c03b200e53095d Is there a tool that gives all the chartbook/chart where a code has been implemented such as for triggering an alert, ecc. ? Thanks for your kind help, A. |
[2017-11-29 18:57:46] |
What message are you referring to? We will not make reference to an external screenshot for security reasons. You need to use the Alerts Manager >> Alerts Log to see what particular chart and study triggered an Alert: Alerts Manager Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-29 18:58:39
