Date/Time: Sun, 24 Nov 2024 04:43:17 +0000
[User Discussion] - Alert Question
View Count: 1377
[2013-09-15 14:02:35] |
jaban - Posts: 66 |
Just want to make an alert when Bar close is higher or lower then a moving average line I tried = OR (C > ID12.SG1 ) , ( C < ID12.SG1 ) and all kind of combinations The individual form works , but not the combination Any help will be appreciated thanks |
[2013-09-15 22:50:13] |
Sawtooth - Posts: 4118 |
This is the proper syntax, but it will alert on every bar: =OR(C>ID12.SG1,C<ID12.SG1) Try this instead: =OR(AND(C[-1]<ID12.SG1[-1],C>ID12.SG1),AND(C[-1]>ID12.SG1[-1],C<ID12.SG1)) |
[2013-09-17 10:07:48] |
jaban - Posts: 66 |
thanks Tomgilb I found another solution , let me know if you agree I added a second ma line , ID13 with ma 1 ( = line on close ) now formule is =crossover (ID12.sg1,ID13.sg1) It looks like it is working correct thanks jaap |
[2013-09-17 13:12:27] |
Yes, that will also work. It is essentially the same.
