Date/Time: Thu, 16 Jan 2025 22:10:53 +0000
Number bar
View Count: 936
[2017-11-28 19:34:18] |
User99934 - Posts: 227 |
1) Is there a way to set the maximum % width of volume profile when using volume relative to all bars? 2) How do I control the thickness of the volume profile outline in number bars? |
[2017-11-29 04:47:53] |
1. No. 2. We need to look into this. It seems like something we have to add. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-29 04:48:09
[2017-11-29 04:51:17] |
Thank you.
[2017-11-29 22:36:14] |
Look at controlling the Display Order: Chart Studies: Study Display Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
