Date/Time: Fri, 17 Jan 2025 19:52:00 +0000
Custom Chart Bar skipping bars
View Count: 1032
[2017-11-28 18:26:11] |
DabbaDo - Posts: 148 |
Attached is my simple test chartbook. The custom chart bar function is SierraChartStudies.scsf_CustomChartBarsExample v1653 The problem is subtle (IMHO nasty). :) 1. I have to be connected (live; I haven't tried it in replay). In my case I'm connected via DTC - Sub Instance to another machine on my LAN, but I doubt if that's relevant. 2. I press UES button to force reloads. (I wish I had a better way.) 3. About 1 time out of 3 I see extremely short volume bars near the end of the chart. http://www.sierrachart.com/image.php?Image=1511893217332.png Debugging into this, I notice that ChartBarInterface.CurrentBarIndex "skips" -- that is CustomChartBarBuildingFunction() is not called for one or more bars. Cheers, Dale |
Debug.cht - Attached On 2017-11-28 18:15:54 UTC - Size: 40 KB - 395 views |
[2017-11-28 18:53:14] |
This will have to wait until later to for us to look into. It is not something we can commit any time to now.
[2017-12-29 08:45:44] |
We have looked at post #1. We have never seen this and have not been able to reproduce this and it simply makes no sense to begin with. We definitely do not think there is any kind of bug like this. We recommend updating to the latest release of Sierra Chart and fully recompiling the code using the current header file. And actually that is necessary anyway with custom chart bars on that version. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-12-29 08:46:21
