Date/Time: Thu, 16 Jan 2025 21:52:47 +0000
Boarder for levels
View Count: 887
[2017-11-28 16:52:09] |
Rino - Posts: 124 |
Hi, Is there a way to have a space for levels/Notes that do not extend over to price/candles? Thanks as always PS Please see Screenshot |
1 aaaa.jpg / V - Attached On 2017-11-28 16:51:01 UTC - Size: 39.71 KB - 319 views Attachment Deleted. |
[2017-11-28 17:52:30] |
Refer to: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-11-28 23:32:57] |
User731023 - Posts: 138 |
I do not want the lines to go across the chart. Like in the snapshot. Do not want to have to cut the lines either. This is important to me please. Thanks PS Please see snapshot |
1 aaaa.jpg / V - Attached On 2017-11-28 23:30:19 UTC - Size: 48.37 KB - 323 views Attachment Deleted. |
[2017-11-29 04:56:06] |
You need to use this particular Study Subgraph Draw Style: Chart Studies: Line at Last Bar to Edge (ACSIL: DRAWSTYLE_LINE_AT_LAST_BAR_TO_EDGE) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
