Date/Time: Thu, 16 Jan 2025 22:03:13 +0000
Numbers bars calculated value study
View Count: 955
[2017-11-28 15:17:19] |
User675163 - Posts: 2 |
Hello, These are two subgraphs that I found under your Numbers bars calculated values study and they are not under my subgraphs tab. Can you please let me know how to get them? Low Bid Volume Percent: This displays the quotient of the bid volumes at the two lowest price points displayed as a percentage. So, Low Bid Volume Percent = Bid Volume at Second Lowest Price Point / Bid Volume at Lowest Price Point * 100. If there is only a single price point that contains volume data, then the Low Bid Volume Percent will be 0. High Ask Volume Percent: This displays the quotient of the ask volumes at the two highest price points displayed as a percentage. So, High Ask Volume Percent = Ask Volume at Second Highest Price Point / Ask Volume at Highest Price Point * 100. If there is only a single price point that contains volume data, then the High Ask Volume Percent will be 0. Thanks, Kyle |
[2017-11-28 17:53:15] |
Update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
