Date/Time: Mon, 14 Sep 2026 13:06:25 +0000
v1652 broke custom chart
View Count: 1031
| [2017-11-27 12:24:59] |
| DabbaDo - Posts: 150 |
At line 184 in the attached study, per the snip below, rChartDataReloadedFlag ALWAYS comes back 1. int& rChartDataReloadedFlag = sc.GetPersistentInt(CUSTOM_CHART_BAR_RELOAD_FLAG_KEY); if (rChartDataReloadedFlag == 0) { sc.FlagToReloadChartData = true; rChartDataReloadedFlag = 1; } But at line 26, the same pattern ALWAYS comes back 0. int& rChartDataReloadedFlag = chartBarInterface.GetPersistentInt(CUSTOM_CHART_BAR_RELOAD_FLAG_KEY); if (rChartDataReloadedFlag == 0) { // Not ready to start yet return; } Dale |
| [2017-11-27 17:53:43] |
We are going to need a few days to look into this.
| [2017-11-27 17:57:32] |
But this really may not indicate a problem. You really should not be relying on that particular persistent integer in the way that you are. Sometimes it is going to be zero like when the custom chart bar study is already on the chart when opening a Chartbook. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-11-27 18:00:05] |
Is this returning 1 when the study is first added to the chart and the chart is reloaded? int& rChartDataReloadedFlag = chartBarInterface.GetPersistentInt(CUSTOM_CHART_BAR_RELOAD_FLAG_KEY);
| [2017-11-27 18:30:00] |
No, chartBarInterface always returns 0 even when the study is first added to the chart and the chart is reloaded. So I see that chartBarInterface.GetPersistentInt(CUSTOM_CHART_BAR_RELOAD_FLAG_KEY) isn't pointing to the same address as sc.GetPersistentInt(CUSTOM_CHART_BAR_RELOAD_FLAG_KEY), and I'll stop relying on it. Cheers, Dale |
| [2017-11-27 18:41:01] |
Bottom line, chartBarInterface.GetPersistentXXX pointed to the same address space as sc.GetPersistentXXX before v1652. Now they point to different areas. Hopefully they don't overlap! :) Cheers, Dale |
| [2017-11-27 18:58:08] |
The address does not matter because a copy is made of the persistent variables during data loading. We will be looking into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-11-27 19:07:02] |
OK we now know what the problem is. We now have this corrected. We will have a new release out today or tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
