Date/Time: Thu, 16 Jan 2025 21:57:09 +0000
1652 issue
View Count: 1231
[2017-11-26 23:30:02]
zippyzip - Posts: 293
no big deal but the label for the volume by price for POC is in values scale no matter where you put label , thanks
Private File
[2017-11-27 18:52:38]
There is no issue here. This is by design for the last Volume Profile. You can use Top or Bottom Vertical Alignment for the Name label and the opposite for the Value label to prevent them from overlapping.
If you want to control this differently, then rather using the extension lines, use the Point of Control Subgraph line:
Volume By Price Study: Calculating and Displaying Developing Point of Control, Value Area High/Low, Volume Weighted Average Price Lines
Go through these instructions step-by-step. You need to go through them and then you will understand. They are very thorough
Date Time Of Last Edit: 2017-12-20 21:14:21
[2017-11-28 13:56:12]
not following as i have choose it on the right , not in the values scale ,
