Date/Time: Thu, 16 Jan 2025 19:50:40 +0000
Wrong Numbers Bars coloring since v1556
View Count: 738
[2017-11-25 20:25:18]
Unlimited - Posts: 1
Hello, I am using the latest SC version v1651 but since v1556 when you changed something on NumbersBars the coloring is (I guess) wrong. I am using only Column 1, with Bid Vol x Asck Vol and Coloring Method is Based on Diagonal Dominant Side AskVol BidVol Percentage.
The Column 1 Percent Compare Treshold is 0.4, 1, 1.5 but values on 0.4 are colored like for 1. It means that values for Range 0 Down/Up is colored like Range 1 which is wrong. Prior version v14xx worked right.
[2017-11-26 01:02:12]
Read the documentation here:
Numbers Bars: Background Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage
The coloring is correct. Make sure you are using Percentage Thresholds that makes sense according to what you want to do.
Date Time Of Last Edit: 2017-11-26 01:02:26
