Date/Time: Thu, 16 Jan 2025 19:49:20 +0000
1649 Trade Activity Log listing a Long Trade when the filter is set for Short Trades
View Count: 922
[2017-11-25 18:22:57] |
User29926 - Posts: 92 |
Version 1649 Trade Activity Log listing a Long Trade when the filter is set to display Short Trades only. Screen shots attached. |
1649 Log error.PNG / V - Attached On 2017-11-25 18:21:56 UTC - Size: 32.43 KB - 283 views 1649 versions.PNG / V - Attached On 2017-11-25 18:22:05 UTC - Size: 5.3 KB - 280 views |
[2017-11-26 01:27:17] |
We are working on a solution to this. There is a problem related to that setting but it is not actually like you are describing. It is a different kind of issue which gives that kind of an apparent result. This issue arose recently. It is not something that has existed for a long time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-26 01:28:45
[2017-11-26 07:41:37] |
This is now fixed in version 1652. Surprising no one else pointed this out earlier. Not sure when this problem had arisen.
