Date/Time: Thu, 16 Jan 2025 20:07:06 +0000
Two Data Feeds On One Instance of Sierra Charts?
View Count: 922
[2017-11-24 17:36:34] |
jsoviero - Posts: 84 |
I am subscribing to Sierra's excellent Data Feed and I am also to BATS Data Feed. I currently run a single instance of Sierra Chart and I display NQ Futures using the Sierra Data, I also display a Real Time Quote Board of a dozen Nasdaq individual stock symbols using the BATS "BZ" symbol suffix. Everything appears to be running and updating in real time with no delay or interruption. Sierra support instructions advise to run an additional instance of Sierra Charts if there is is an additional data feed? Please advise if the additional instance of Sierra is necessary when subscribing to two data feeds (Sierra and BATS?) Also please advise the correct BATS Symbol for the Nasdaq cash index. Thanks in advance for you helpful replies. |
[2017-11-24 20:48:57] |
Sierra support instructions advise to run an additional instance of Sierra Charts if there is is an additional data feed? In regards to the symbols for the cash indices, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CashIndexes You will need to activate the NASDAQ Indices exchange if you want real-time data for those indices. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-11-24 20:49:20
