Date/Time: Thu, 16 Jan 2025 19:46:37 +0000
Value limit for order size (prevent typo / fatfinger)
View Count: 769
[2017-11-24 14:58:18] |
User910178 - Posts: 1 |
Hi, can I set a value limit for order sizes to prevent typos? e.g. value limit is set to 50000 will prompt a warning when I accidentally try to buy 300000 instead of 30000. It's a feature in IB TWS for example. Alternatively, I can I type 30k instead of 30000? This would also prevent a fat finger accident which already happened to me :) Thanks |
[2017-11-24 20:42:55] |
No, this is not supported within Sierra Chart.
